Slight movement on ...
[Closed] Slight movement on Centrelock hub/disc interface
I've got a set of M776 wheels with 180mm XT rotors.
Everything is nice and tight, the hubs are recently serviced and rotors are securely fastened.
However, with the front brake applied, there's still a bit of movement on the front wheel while the disc appears to remain stationary. It's not a lot - probably 3mm at the tyre - but you can see the spokes/hub move next to the disc.
I've recently changed the disc from an XTR to an XT and, as mentioned above, stripped the hub down. The lock-nut is fastened as tight as I can get it using a [url= http://www.wiggle.co.uk/shimano-bb-spanner-for-hollowtech-ii-cups/ ]short-handled Shimano BB tool [/url], but there's still movement.
Finally, it's definitely at the disc/hub interface and not the headset!
Any comments/ideas?
Posted : 06/04/2011 10:58 am
sure its not brake pads moving in the brake caliper?
Posted : 06/04/2011 10:59 am
Yeap - already checked that one too. Pads are pretty new and I don't get the movement with a King/6 bolt Shimano disc set-up.
There's a definite 'clunk' feeling at either end of the movement as well.
Posted : 06/04/2011 11:03 am
maybe the bolts rivets fixing the steel rotor to the alloy carrier have worn the carrier a bit? One of my riding mates has the same issue and you can hear them rattle as he rides along.
Posted : 06/04/2011 11:06 am
When you put the rotor on without locking it down does it move on the splines? or if not that, The discs are riveted to the aluminium carrier, maybe there's play in the rivets.
6 seconds too late.
Sounds like either QR not done up tight enough (unlikely as you've had it apart and back together again) or the cup n cones not quite right.
3rd the carrier rivets, after melting my rear pads and their backing plates, my rotor took a beating XT160 splined. What you describe happens on the rear of my bike when the brake is locked on.
I can feel the play in the carrier so I would look at that (reminds me to buy a new one)
Posted : 06/04/2011 11:12 am
Cool - cheers guys. I'll check the carrier.
Posted : 06/04/2011 12:59 pm
