Slack 4" frame...
[Closed] Slack 4" frames?
[#3863107]
Chaps,
Quite fancy building up a slack 4" frame ....
Struggling to come up with any viable alternatives though...
Ideally, looking for a trail bike as opposed to a 4x frame (old Meta 4 was an amazing bit of kit, but not for climbing!!)...
Depending on the frame, offset bushes or an angleset will help with geo.
Current shortlist:
Trance X
Meta 4
I'd rather go nearer 4 than 3".....
Other options?
Posted : 12/04/2012 11:21 am
SC Nickel.
Posted : 12/04/2012 11:22 am
New short travel cotic rocket 😉
Posted : 12/04/2012 11:23 am
I was looking for the same thing. Closest I got was a kona kikapu. 4 inches of travel and a 68.5 head angle.
Other option is an old giant trance 06/07 with offset bushings/works headset.
Posted : 12/04/2012 11:25 am
GT Distortion (starting to feel like a GT rep now)? 4 inches and 66.5 degrees
Posted : 12/04/2012 11:28 am
SC Blur xc Carbon - 68.5 headangle with some 120mm forks - not as xc biased as some might think!
Posted : 12/04/2012 11:29 am
 SamB
Intense Tazer VP is 3.25"-4" adjustable with a 68 degree HA. It is proper small though!
Posted : 12/04/2012 11:36 am
Pivot M4X?
Posted : 12/04/2012 11:39 am
Look no further:
REAR TRAVEL: 80mm (3") or 100mm (4") Rear Wheel Travel
REAR SHOCK: 6.5" x 1.5" (Forward Pin 22.2mm x 8mm, Rear Pin 22.2mm x 8mm)
FRAME MATERIAL: 6061 Heat Treated Aluminum
SIZES: Regular, Long
COLORS: Orange, Black, Raw
FRAME WEIGHT: 7.9 lbs / 3.6 kg (Medium Frame With Rear Shock)
COMPLETE WEIGHT: 31.3 lbs / 14.2 kg (Medium Bike)
WARRANTY: 2 year defect warranty, Lifetime crash replacement
SEATPOST/CLAMP: 31.6mm Seatpost/34.9mm Clamp
HEADTUBE: Tapered 1.5" / 1-1/8" (1.5" Lower Cup 49.6mm ID / 1-1/8" Upper Cup 44mm ID)
BOTTOM BRACKET: 73mm shell x 51mm chainline
REAR DROPOUT: 142mm x 12mm (Shimano e-thru) + 135mm x 10mm option
FRONT DERAILLEUR: Not Compabible
CHAINGUIDE: ISCG 05
I think one of the Dirt lads uses one for general trail riding - i suppose it depends on how tall you are.
Posted : 12/04/2012 11:51 am
Look out for an old Kona Howler. They did them in red for 2006 and then green and white for 2007. I had one and swapped the 200mm eye to eye shock for a 190mm coil and it slackened it and lowered it beautifully. The seat angle is pretty steep anyway, so climbing didn't suffer. Can't take a front mech though so it's 9 or 10 speed only. Superb fun bike that I should never have sold really.
[url= http://farm3.staticflickr.com/2686/4334437797_98429fb55c_z.jp g" target="_blank">http://farm3.staticflickr.com/2686/4334437797_98429fb55c_z.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/rick2/4334437797/ ]Trail Centre Razzer[/url] by [url= http://www.flickr.com/people/rick2/ ]Rick T.[/url], on Flickr
Posted : 12/04/2012 12:35 pm
