SKS rennkompressor....
[Closed] SKS rennkompressor. Any recommendations for a new head?
So I have had the above pump for a few
Of years. Whilst it’s a nice thing to use the head has been poor. It came with a single auto adjusting type which soon stopped working so was replaced with a dual head.
Likewise that is poor and no longer wants to inflate schraeder type valves which I need to top up the tubeless inflator and for the kids bikes.
Can anyone recommended a head which will do both presta and schraeder that will definitely fit the sks hose?
Posted : 19/08/2019 12:39 pm
https://www.bike-components.de/en/SKS/Multivalve-Pump-Head-p22240/
Edit, my bad, I see you already tried their dual head
Posted : 19/08/2019 12:42 pm
i binned mine off and fitted the one from a cheapo pump
Posted : 19/08/2019 1:15 pm
Mine got replaced by a Twin Head I think it was from Topeak. It leaks a little but then it is about 10 years old and on the original rubber so not bad.
Posted : 19/08/2019 1:34 pm
I stuck a Topeak Smarthead on my Rennkompressor, works fine and, from memory, fits the hose. I didn't get the whole upgrade kit with hose attached, just the head and it's still attached and working.
Posted : 19/08/2019 1:37 pm
Cheers folks. Sounds like it’s a pretty standard hose size.
Posted : 19/08/2019 1:39 pm
I’ve had two of these (the first got stolen from the car). The auto adjust head I didnt get on with either but I’ve never had an issue with the dual head.
Does it just need new rubber seals?
Posted : 19/08/2019 2:26 pm
The original head mine came with with the schraeder valve and the screw fit presta adapter was the best I’ve had. The twin head is a bit hit or miss, sometimes it works sometimes it doesn’t which isn’t ideal.
Posted : 19/08/2019 2:36 pm
It’s hardly been used for schraeder. I think they rely on a see saw type seal inside which probably gets gummed up. Trouble is you can’t get to it to clean it.
I have managed to salvage an old black burn head which fitted the hose so it’s sorted.
Thanks all.
Posted : 19/08/2019 9:01 pm
Topeak SmartHead. Pumped up the front car tyre with mine yesterday
Posted : 19/08/2019 9:17 pm
