Singlespeed Front C...
[Closed] Singlespeed Front Chainring Question
[#775705]
I have just bought a singlespeed Genesis IO 2007 however the front chainring is to large. I am looking at replacing it with a 32t ring up front. The crank has four bolt points. Does anybody know if a standard four bolt 32t middle ring will do the job??
Posted : 11/08/2009 10:37 am
Should do, as long as it's the right BCD. The ring that's on there now might have the BCD on it somewhere if you're not sure, but would've thought a standard MTB ring would go.
Posted : 11/08/2009 10:39 am
Should be fine unless Genesis are speccing something very wierd.
Posted : 11/08/2009 10:42 am
Yes but "standard" ring has ramps to aid shifting which you don't need. Try an old one and see how you get on with the new ratio. Then buy something nice 🙂
Posted : 11/08/2009 10:46 am
Will the ramps affect the performance in any way?
Thanks
Posted : 11/08/2009 10:57 am
If your chain's not tight then the ramps can make the chain come off more easily. Only a (slight) problem if you're using a tensioner (doofer). Which you're not.
Posted : 11/08/2009 11:00 am
Cheers everbody for the advice
Posted : 11/08/2009 11:03 am
Cheers everybody for the advice
