Hello
i got a singlering Truvative Touro 48t crankset, what chain does it need, i would like a kmc?
and combine it with a Fire Eye FE-SSK Single Speed Spacer 2 Cog Kit
will probaly buy from here :
http://www.bike-components.de/shop/cat/c9012_Ketten.html
or here
http://www.chainreactioncycles.com/Categories.aspx?CategoryID=79&SortBy=Price
oh forgot i also have a 8 speed crankset, what kmc chain should i run with that and with the fireeye spacer kit?
I'm using a KMC Z610 for single speed and Rohloff.
The silver ones were lasting well, so I thought I'd try the cheaper Rustbuster. That seems to have worn a bit quicker, so I'll go back to silver.
I presume this chainring is orginally part of a multi gear setup, if so a 3/32" chain will work fine. I run two single speed one with a 1/8" chain and the other with a 3/32" - the difference the 1/8" chain weighs a bit more. Use a Z82 3/32" chain cheap and chearful.
