Singlespeed chain f...
[Closed] Singlespeed chain fitting advice...
[#1269733]
So I have nearly finished the build, the only thing left to do is fitting the chain. It's got standard drop outs, so I have bought a tensioner and a half link. So just wondered what the general view is, do I try and do it without the tensioner, or go tensioner with chain as tight as possible, or do I need some slack inorder to get the back wheel out.
thanks...
Posted : 28/01/2010 4:45 pm
I'd say tensioner, anything else on a standard dropout frame is a short-term measure. In my experience, magic ratios don't stay that way for long.
Posted : 28/01/2010 5:07 pm
tensioner and get the chain as tight as you can (unless its too tight).
Posted : 28/01/2010 5:22 pm
so whats the standard for removing a rear wheel on a SS then?
Posted : 28/01/2010 6:34 pm
If you have a tensioner, a QR and vertical dropouts, it is no more difficult to remove the rear wheel than if you had a derailleur. Had no problems in the time I had a tensioner for a cheap commuter singlespeed.
Posted : 28/01/2010 6:39 pm
