Singlespeed boost
[Closed] Singlespeed boost
[#9419437]
I ride a singlespeed setup, call me nuts but I enjoy it and the trails around me are fairly flat so it just suits.
My main ride is a Stanton Sherpa in 29er mode. It doesn't have an eccentric BB so I have the horizontal swopouts and use a DT Swiss RWS QR skewer to hold the wheel in place.
Now I want to try some 27.5+ wheels and it seems to make sense to go for a boost hub, if I can make it fit. So the question is can I get a hub which takes a 5mm QR skewer and can I get a skewer long enough for 148mm? (sorry that's two questions) Cheers
Posted : 05/07/2017 5:54 pm
Happy to be corrected, but I'm pretty sure all boost hubs are 12mm through axles.
Posted : 05/07/2017 6:31 pm
 edd
You can get a QR boost but it is 141mm wide...
(Same hub as 148 boost but QR end caps - same relationship as 135mm x QR to 142mm x 12mm through axle.)
Posted : 05/07/2017 6:38 pm
Assuming your current frame is 135/142mm OLN, then your first problem with a boost hub is that the brake disc will be 3mm outboard. Struggling to see what any benefit from boost would be in this case?
Posted : 05/07/2017 6:42 pm
The Sherpa frame is actually 145. Designed that way to flex either in or out by 3mm to 142 or 148.
[b]edd[/b] - tell me more about that 141 QR boost - I didn't quite follow what you were saying. And who makes/where can I get it?
Cheers.
Posted : 05/07/2017 7:13 pm
