Singlespeed
[Closed] Singlespeed
[#1948646]
I've a few questions for the panel about singlespeeds:
Are they really more muck-resistant than geared setups (getting tired of chainsuck & shifting problems riding in Pennine muck)?
How easy is getting the chainline sorted?
What sort of ratio would be good (bearing in mind I don't want to kill my knees)?
Is facial hair also a requirement for riding a bike with one gear?
Ta
Andy
Posted : 31/08/2010 6:16 pm
Are they really more muck-resistant than geared setups (getting tired of chainsuck & shifting problems riding in Pennine muck)? [b]Yup[/b]
How easy is getting the chainline sorted? What chainline adjustment?? [b]On a ss specific frame it's reet[/b]
Is facial hair also a requirement for riding a bike with one gear? [b]32:16 is how most roll. Facial hair is not a requirement[/b]
Simples 😀
Posted : 31/08/2010 6:20 pm
Yes
Fairly
2 to 1 (32:16 etc) or 32:18 depending on knees/terrain
Whatever
Posted : 31/08/2010 6:21 pm
Yes
So long as you get different size spacers to go on the free hub it's easy.
personal choice - I run 32:18 rather than 32:16 as I prefer to have a higher cadence but now I'd run odd ratios to even chain wear out maybe 32:17.
No but I'm sure it helps.
Posted : 31/08/2010 6:22 pm
Dunno
Fairly (but not sure it's such a big problem, equally ss specific chain wheels)
32:16 to start with
Clean shaven, chisel jawed, Nº1 haircut (dunno)
Posted : 31/08/2010 6:25 pm
❓ have i missed something in singlespeed school?
Posted : 31/08/2010 6:26 pm
Yeah proper muck resistant, haven't cleaned mine since I got in in May.
I run a 32:16, but live in Cheshire, but a 32:17 may be better in the Pennines.
Chain line is dead easy, especially if you run a SS specific hub.
I've got some smallish sidies and occasionally don't shave for 3 days.
Oops, meant chain ring / sprocket wear not chain wear.
Posted : 31/08/2010 6:35 pm
Thanks all.
Another stupid question:
Assuming I'd be using a frame with vertical dropouts & a fixed BB, what chain tensioner do people recommend?
Andy
Posted : 02/09/2010 9:53 am
BLING = White Ind Eccentric Eric hub OR eccentric bb cup thingy
NORMAL = push / pull tensioner (on one/surley etc)
CHEAP O = old rear mech
GOD = magic ratio
http://www.sheldonbrown.com/singlespeed.html
Posted : 02/09/2010 9:55 am
Magic ratio. A half-link increases the chances of finding one. I use a ghost ring when I need a tensioner.
Posted : 02/09/2010 9:56 am
i'd recommend gusset tensioner from charlie the bike monger. best one ime.
Posted : 02/09/2010 9:58 am
I bought the On-One tensioner because it was the cheapest and it works prefectly well.
Posted : 02/09/2010 9:59 am
Yes, that's pretty much the only reason I have one.
If you're not silly enough to use a SS specific hub and just use a normal back wheel with sprocket/spacers then it's very easy.
Start off around 2:1 - 32/17 for me - find a gear that works on your geared bike and do that.
No, luckily as I look stupid if/when I grow a beard.
Posted : 02/09/2010 10:00 am
you been singlepeeing long
Posted : 02/09/2010 10:02 am
Q) Are they really more muck-resistant than geared setups?
A) yes
Q) How easy is getting the chainline sorted?
A) don't know - it's never been a problem
Q) What sort of ratio would be good
A) try 32:16 to see how hard it is - then a 32:18 if you'd like the climbs to be a bit easier.
Q) Is facial hair also a requirement for riding a bike with one gear?
A) optional - i wouldn't say i've got a beard, but i do have face-fuzz
(if you ease youself into it (32:18) and build up slowly, and allow yourself to walk the really steep bits, it really won't damage your knees)
Posted : 02/09/2010 10:09 am
Doesn't the muck resistability depend on whether you've got a tensioner or not ?
Having used a Rohloff on a full sus and various hardtails, I'd go for an EBB or sliding dropouts every time for simplicity and reliability.
Posted : 02/09/2010 10:11 am
Can't say that I've ever noticed any difference with or without a tensioner other than less noise and easier wheel removal on a SS specific frame.
Posted : 02/09/2010 10:13 am
Just returned to SS'ing, doubt I'll be returning to gears any time soon.
Posted : 02/09/2010 10:16 am
Things that tough in the biz then KT? Next you'll be telling me you've sold the ****-wagon 🙂
Posted : 02/09/2010 10:18 am
I've been thinking about going one stage further and doing away with the chain altogether.
ratherbeintobago - Member
...Is facial hair also a requirement for riding a bike with one gear?
It is preferable if the single speed girls don't have facial hair. 🙂
Posted : 02/09/2010 11:57 am
I used to use the DMR STS, simply because it was unsprung. I had tried the old Surly design, but I couldn't get the spring tight enough to hold the chain on through the rough stuff. Sure, with the bolt in one, you have to adjust the tension every once in a while, but you'd do that if you take the wheel out anyway.
The DMR one, however, won't take a 1/8" chain - but a quick session with a hacksaw and a file opened the groove out enough to do it.
Then I bought a proper SS frame and it is lush!
Posted : 02/09/2010 12:29 pm
 69er
a) very easy
b) Depends where you live, start 2:1 26er or 2:1 plus 2 teeth 29er
c) Yes or no depending on wether you want facial hair
Posted : 02/09/2010 12:41 pm
All easy.
Don't bother hunting for a magic ratio, get a chain tensioner.
Much better for mud (chain stays well away from the back wheel which helps a lot).
34x18 for me on the 26er and 32x18 on the 29er. I can get up most stuff but if I can't I get off and walk.
Facial hair - you should definately grow a handlebar moustache and a weird goatie in combination - then shave your head! 😆
Posted : 02/09/2010 1:03 pm
 will
Ratio really does depend where you ride I think.
As your riding inthe Pennines I'd also suggest a 32:16. You spin out at around 17mph... which is annoying, but you can still climb easy enough with that ratio.
Posted : 02/09/2010 1:08 pm
I returned to SS'ing about 18months ago.
I used a 32:18 to start with as my fitness was rubbish - Last spring and summer was full of pain! Now on 32:16 which is about right on Mendip.
17mph is a bit fast for spinning out on 32:16. I reckon its closer to 14-15mph, but whats a couple of mph between forum posters eh?
Posted : 02/09/2010 1:18 pm
 will
😆 Have to admit that was a guess. Trying to keep peddling at 20+mph is funny, and actually just about do-able...
Posted : 02/09/2010 1:21 pm
the On-One tensioners are cheap on [url= http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=110580336888&ssPageName=STRK:MEWNX:IT#ht_3113wt_1137 ]Ebay[/url] £8!
[u]Don't[/u] get one of these -
They are crap (IME)
Posted : 02/09/2010 1:22 pm
Isn't it about time there was a s/s faq?
No disrespect to the OP but this crops up every week [b](at least)[/b] and as people seem incapable of using the search function, either a faq or link to Sheldon would cover all the areas.
Posted : 02/09/2010 1:27 pm
That would seem eminently sensible.
I have some webhosting so could host a page on it if that would be helpful.
Andy
Posted : 02/09/2010 2:44 pm
Already done
http://www.mtbr.com/ssfaqcrx.aspx
Posted : 02/09/2010 2:56 pm
RBIT
No real need Andy - it's all [url= http://www.sheldonbrown.com/singlespeed.html ]HERE - Sheldon Brown Singlespeed[/url]
If you weren't on the other side of the Pennines I'd offer to help you sort it out as I have numerous spares to get chainline, gearing etc. spot on, built up over years of trying out different options.
Edit - forgot about that one Clubber 💡
Posted : 02/09/2010 2:59 pm
Would you say it took you about 6 months to fully adapt to SS?
Posted : 02/09/2010 3:13 pm
No - about one minute 😉
Posted : 02/09/2010 3:16 pm
[i]fully adapt to SS[/i]
Fully adapt to just pedalling, steering and braking?
Posted : 02/09/2010 3:18 pm
It's more the SS attitude that takes the time to pick up - you know - the casual 'I'm better than you because I don't use gears' one 😉
Posted : 02/09/2010 3:20 pm
And when you do the moment is generally celebrated with the application of a 'one f****** speed' or 'gears are for queers' sticker on your chain stay.
Posted : 02/09/2010 3:24 pm
Indeed. Lame.
Posted : 02/09/2010 3:25 pm
Not to mention the grand sticker of all 'Gears are for F*** C W******'.
Posted : 02/09/2010 3:26 pm
I've only had a short outing on mine so far (which was very good), but it seemed quite different from my geared riding; I'm such a spinner normally. The effect of dumping ~2.5lb of gearing equipment off the bike was also very noticeable.
I was just picking up on ScienceOfficer's remark about Spring and Summer being painful. Like him I'm starting out with 32:18. I am wondering about how long it's going to take to develop the "internal gears and power" to climb our local trails competently. I was kinda hoping that if I'm persistent over autumn then by winter time I'll have cracked it.
Posted : 02/09/2010 3:33 pm
be careful tho the more you do it the more bling you crave, the first bike i ran ss was in 96 i snapped my rear mech and lived in belgium it was old old gear and the fella in the shop said new shifters/cogs/chainrings the lot was needed as it was all now 7 or 8 speed (maybe even 9 cant remember but it was more than i had) so i converted as it was cheaper and not many hills in belgium and all these years later ive just bought white eno cranks and boone ti ring ;-(
Posted : 02/09/2010 3:39 pm
Loving the bristol contingent swear-athon!
There is an adaptation of mindset, but that doesn't take long. If you've got a bloody minded streak just let it run free!
I'd say it took me about 6 months to to get fit enough to enjoy it properly, and increase my pain tolerance.
None of that is SS specific stuff though. Just fitness stuff, and I wasn't very fit and was overweight. You're starting from a higher baseline, so if you're persistent in Autumn like you say, you may well be ok.
Either way, come the slippery slop, we'll all be walking in places.
This I did find to be true - started off with a real bodged up bike of whatever I had/could get cheap or free but then at some point realised that my SS was the bike that I rode most (for reasons of mud rather than because I actually prefer it) so decided to build up something nice...
Posted : 02/09/2010 3:44 pm
Well, there's a first. 😉
Posted : 02/09/2010 3:53 pm
