Single front chainr...
[Closed] Single front chainring
I have a 2011 specialized camber. I have quite a lot of upgrades on the bike, to finish it off i would like to have a single front chain ring to save weight etc. my question is, is it just as simple as removing the granny ring and large ring from my front setup. I was under the impression that it uses spacers from the large ring to hold the middle ring?
Posted : 25/03/2014 11:06 am
youll probably need shorter bolts, or some fat washers
Posted : 25/03/2014 11:07 am
Yes, you need shorter bolts, or washers. You need something to keep your chain on too. If you've got a clutch rear mech then a narrow/wide chainring is the neatest, otherwise a top guide such as those from Superstar/MRP/E.13 is a good idea.
Posted : 25/03/2014 11:08 am
Does crc do the bolts? Im thinking a single chainring with blackspire stinger would be suffice?
Posted : 25/03/2014 11:18 am
 GEDA
I have a thick thin and although I have a clutch mech I often forget to put it on and the chain still stays on. This is over big drops, jumps and a bit of clattery downhills.
Posted : 25/03/2014 11:30 am
http://www.amazon.co.uk/TruVativ-Steel-Chainring-Bolt-Set/dp/B001GSQO3W
They should do you for a single ring up front.
Posted : 25/03/2014 11:32 am
[url= http://lmgtfy.com/?q=short+chainring+bolts+site%3Achainreactioncycles.com ]LMGTFY[/url]
Posted : 25/03/2014 11:41 am
 SamB
