Silly seatclamp que...
[Closed] Silly seatclamp question
[#3577416]
Just bought a dropper post so i need a bolt-on seat clamp to stop it going walkabout, inner diameter is 30.9, what size clamp do i need? 😳
Posted : 17/01/2012 10:09 pm
take it 30.9 in the dropper diameter?
depends on you frame for the seat clamp size , alloy tube with be thicker than steel for example.
Might be an idea to mention what bike you have
Si
Posted : 17/01/2012 10:11 pm
What size front mech clamp do you have? Its the same as that, most likely 34.9 on an ally frame
Posted : 17/01/2012 10:15 pm
unless the seat tube is externally butted near the seat clamp.....
Posted : 17/01/2012 10:22 pm
Probably 34.9.
Posted : 17/01/2012 10:25 pm
Ooops! Its a Marin Wolf Ridge 6.8 2009 model 😳
Just googled the bike and haven't found anyhting about the external seat tube diameter. The seatpost diameter is 30.9, not the internal seat tube diameter.
Posted : 17/01/2012 10:29 pm
muddydwarf - Member
If they're not the same, you have a problem 🙂
Posted : 17/01/2012 10:31 pm
Well yeah, but the internal seatube diameter isn't going to be exactly 30.9mm is it? I work in engineering manufacturing and i know enough that 30.9 won't go into 30.9! 😛
Actually, i wonder what the tolerance is...
Posted : 17/01/2012 10:37 pm
well surely if you work in engineering you have access to a vernier caliper ? 😯
Posted : 17/01/2012 10:46 pm
I do, but its at work and i'm at home with an internet connection and a credit card! 😆
Posted : 17/01/2012 10:55 pm
[url= http://singletrackworld.com/forum/topic/309-seatpost-means-318-seatclamp-right ]Linky[/url]
Posted : 17/01/2012 11:06 pm
Sorted Scotsman - ta for that, although i am a bit worried about how easily you found that thread... Do you have powers of total recall??? 😯
Posted : 17/01/2012 11:15 pm
Google search (Marin Wolfridge seat clamp diameter) and up pops STW top of the page! But I am at work sitting in a hotel in deepest darkest West Africa (Nigeria) with nothing better to do!
Posted : 17/01/2012 11:24 pm
