SID Race Forks - Ca...
[Closed] SID Race Forks - Can you retro-fit a Poplock or whatever its called?
 JB
[#289127]
I've acquired a set of SID Race forks (a couple of years old) with no lock-out. Anyone know if you can get hold of the lockout/Poplock element separately and retro-fit???
Posted : 09/02/2009 1:56 pm
Does your fork have a blue dial on the top of the leg with a slot running round it's edge for you to fit a cable in (secured via a grub screw)?
If so, then you probably can. I think the actual lever on it's own though is quite expensive for what it is.
Posted : 09/02/2009 2:12 pm
People often misinterpret the word "poploc" to mean "remote control switch" which it isn't - my Reba has poploc but it's not remote... but I can't answer JB's question either.
Don't SID's have slimmer stantions than other RS forks? If so I very much doubt that the internals are interchangable.
Posted : 09/02/2009 2:17 pm
 JB
Hmmm no idea... will have a look later, but i suspect that even if it is possible the cost is likely to be prohibitive.
Posted : 09/02/2009 2:18 pm
Aaaaah, yes, I misunderstood....if you can't lock out your fork even with a dial on the leg then I doubt you'll be able to do it.
Yes, older SID forks had narrower stanchions so i think the upgrade kit wouldn't be a go-er. Hmmmm.
Posted : 09/02/2009 2:38 pm
Eh? What is it, then?
I have a little lever switch thingy on my bars. It goes 'Pop!' 'Loc!'. And it locks my fork out, from a remote location. Sometimes, even Hackney.
Posted : 09/02/2009 2:46 pm
