I have a 100mm SID - RLT - Am I right in assuming I can add/remove a spacer to make it 120mm? Or was it the 120mm that can be made 100mm?
๐
Posted : 12/04/2013 12:27 pm
My 120mm SID came with said reducing spacers (2 x 10mm thick) but I'm not sure if the 100mm version is already spaced - it may depend on year? Give Loco a ring?
Posted : 12/04/2013 12:32 pm
100/80 are interchangeable, and 120s can be dropped, but you can't extend a 'proper' 100 to a 120, unless it spaced anyway.
Posted : 12/04/2013 12:50 pm
Do the stanchions have sag markers for 120mm? If not then chances are you have the 100/80mm version only.
Posted : 12/04/2013 3:21 pm
njee20 - Member
100/80 are interchangeable, and 120s can be dropped, but you can't extend a 'proper' 100 to a 120, unless it spaced anyway.Posted 2 hours ago # Report-Postjairaj - Member
This, Ok thanks 100mm they remain.
Posted : 12/04/2013 3:28 pm
