SID fork bushing no...
[Closed] SID fork bushing noise.
2021 SID Ultimate's purchased 08.2020 but only just fitted 75 miles on them.
At first thought it could be caliper/pads but have removed the pads and the noise is still present.
Would describe the noise as a slight clicking / light knocking noise. Seems to be getting more noticeable every ride. Is this going to be the much reported issue with the bushings in the SID.
Best way to test / reproduce the issue in a static test ?
Posted : 17/04/2022 9:10 pm
Give them a lower leg service. My SID Select+'s did that from new but it went away after dropping the lowers and putting the proper amount of oil / grease in. They come really dry from the factory.
If no joy then yeah, could be the dreaded busing issue. SRAM will replace the lowers under warranty.
Posted : 18/04/2022 2:58 pm
Thank you sounds like a good plan and go from there.
Posted : 18/04/2022 3:32 pm
