I'm just about to replace my SIDs.
I need 80mm travel to suit the geometry on my Explosif.
I can find SID Race "100mm" cheaper than I can find "80mm".
Is it one or the other or are they adjustable? If they are adjustable, is it by servicing the fork? If it's by servicing the fork, can I easily do it myself?
I can't find the answer on the SRAM site.
Ta.
Martin
I have just got a new bike and it came with sid World cups on and i got some plastic spacers with it to make it in to 80mm down from 100mm.
I think most rockshox 100mm'ers are like this, i know my reba's all i need to do is put some spacers in there to drop the hight.
So i guess you just need to check if the forks that you are ordering come with the 20mm drop spacers.
Hope this helps.
If you need you can have my spacers, cos i will never use them, but you will ahve to make sure they will work on your (new)forks.
Nezbo
Forks should come with the spacers. Is roughly a 15 minute job. The only really odd tool you'll need is a very deep socket to slide over the negative valve in the LH lower.
If the spacers aren't in the box, drop me an email and I'll fire you some in the post.
Manuals on the SRAM site, and relevant videos on youtube.
