Show me your diy he...
[Closed] Show me your diy helmet light mounts please...
[#2151019]
I am busy converting a LED torch to mount on my lid. It will have a separate battery pack and a wire to the modified and shortened torch body. I need some genius ideas for mounting it. Anyone got any wizard plans? Cheers.
Posted : 02/11/2010 8:43 pm
your best bet is to use an existing mount.
I got a cateye helmet mount and screwed the 'light' half of the mount to the torch - was really secure and allowed proper adjustment of the light once on the helmet.
Posted : 02/11/2010 8:48 pm
mine is simply a couple of o rings and a cable tie holding them together, Thread it thru a vent hole at the top of the helmet and back out thru one at the back leaves two rubber loop to thread the torch shaped body thru - a bit of foam under it to stop it sliding about.
I strongly believe in a breakaway mount for the light - this holds it steady and would come off if caught on anything
I'll sort a pic out
edit - I altered the design - I forgot
Pics in a mo
Posted : 02/11/2010 9:16 pm
Zipties... 🙂
Posted : 02/11/2010 9:19 pm
 tang
cut inner tube mount(similar in principle to tj) and tesco torch. there are some pics on here somewhere.
Posted : 02/11/2010 9:21 pm
 jonb
also works on a helmet. Probably a bit late for my patent now. Ghetto helmet mounts (tm)
I bought some lockblock things of ebay. Two perpendicular velcro straps with a rubber mount between them. Much better and only a couple of quid.
Posted : 02/11/2010 9:22 pm
I just have a £6 walking head torch on mine - the straps work a treat at holding it in place.
Posted : 02/11/2010 9:25 pm
[url= http://farm5.static.flickr.com/4060/5140864894_890639fcfc.jp g" target="_blank">http://farm5.static.flickr.com/4060/5140864894_890639fcfc.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/25846484@N04/5140864894/ ]hee 001[/url] by [url= http://www.flickr.com/people/25846484@N04/ ]TandemJeremy[/url], on Flickr
[url= http://farm2.static.flickr.com/1132/5140868658_bbb3841c50.jp g" target="_blank">http://farm2.static.flickr.com/1132/5140868658_bbb3841c50.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/25846484@N04/5140868658/ ]hee 002[/url] by [url= http://www.flickr.com/people/25846484@N04/ ]TandemJeremy[/url], on Flickr
Posted : 02/11/2010 9:28 pm
[url= http://farm1.static.flickr.com/99/286189285_c5d0fe9da7.jp g" target="_blank">http://farm1.static.flickr.com/99/286189285_c5d0fe9da7.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/brf/286189285/ ]Homemade helmet mount[/url] by [url= http://www.flickr.com/people/brf/ ]brf[/url], on Flickr
Posted : 02/11/2010 9:37 pm
Posted : 02/11/2010 9:52 pm
Thanks for the input guys. Great ideas
Posted : 02/11/2010 10:16 pm
 GW
for me, a couple of strips of 3M dual lock (industrial velcro) and a velcro cable tie is more than enough to hold a DX P7 torch on my head.
anyone mount a light on their head without a helmet?
Posted : 02/11/2010 10:23 pm
GW - Member
I fitted a couple of M6 studs in my skull especially for this. Ti of course
Jonb has the best design - I shall steal it
Posted : 02/11/2010 10:27 pm
