Shortening Lock-on ...
[Closed] Shortening Lock-on grips - anyone done it?
[#9717543]
The grips on my daughter bike are falling apart so decided that she needed some new ones.
I've ordered a pair of Superstar lock-on's with 2 rings.
This'll be OK on the LHS, but the RHS has a grip shift. Has anyone successfully shortened a lock on grip?
I had an idea of just cutting one end off and using a single lock ring - she's only 7 so shouldn't be able to twist it.
Then I thought about taking the rubber grip off the plastic cartridge and and cutting the middle section out of the plastic cartridge, trimming the rubber grip and putting back together with 2 lock rings.
I know I could have got the correct (pricey...) short grips but where's the fun in that 😀
Posted : 13/12/2017 7:14 pm
Never done it but Your idea of cutting a section out of the middle is what i'd do, if you think you can get a decent join and / or she tends to wear gloves.
If not, no outer lockring might be the way to go.
Posted : 13/12/2017 9:39 pm
Was going to use my steerer cutter guide to get the joint level. Either that or pipe cutters.
I was going to take off the outer cover and trim from one end so that it's continuous when I put it back on so no join.
Posted : 13/12/2017 9:43 pm
I've used SS grips with the outer ring tabs cut off with no bother in the past.
Posted : 13/12/2017 9:49 pm
I just cut the ends off them on my sons bike and butted the lock ring up against the cut edge. I couldn’t get them to spin by twisting and you can’t tell to look at them.
I don’t think I would want a join in the middle as it may pinch skin if they ever moved.
Yep I've done it to use with a Rohloff shifter.
Just cut it with a hacksaw and use the outer clamp only.
ODI actually do a grip specifically for gripshifts but having a locking ring in the middle of the grip isn't very comfy...
Posted : 13/12/2017 9:57 pm
singlespeedstu - Member
ODI actually do a grip specifically for gripshifts [b]but having a locking ring in the middle of the grip isn't very comfy[/b]...
Hadn't thought of that - will go with one ring on the outside then I think.
Posted : 13/12/2017 10:15 pm
I've just done that today.
Used steerer cutter.
Have not yet completed the bike, but I don't expect any problem.
Posted : 13/12/2017 11:37 pm
Yup - done this on my bikes. Simply cut with a hacksaw
Posted : 14/12/2017 12:14 am
I did precisely what you describe, my daughter has a half-pipe grip shifter on the RH side, so only needed another 30mm or so of grip, roughly chopped it off with a hacksaw then finished off with a dremel, Single lockring at the end of the bar...
Posted : 14/12/2017 1:24 am
Thanks chaps!
Posted : 14/12/2017 1:29 am
