Shortening Hope hos...
[Closed] Shortening Hope hoses without bleeding
I know there's a good chance of getting away with it on shimano brakes but anyone got any tips or experience with hope brakes. I actually don't need to shorten the hose but do need to run the hose internally on a new frame. Thank you.
Posted : 27/07/2015 3:59 pm
remove the pads,
squeeze the lever,
cut the hose, reattach
push the pistons back
refit the pads.
all of the above should be done with your fingers crossed.
assume a full bleed for avid juicys!
Posted : 27/07/2015 4:02 pm
I'd be prepared to bleed if I was you ( definitely more susceptible to air ingress than Shimanos)
Bleeding is a breeze on them though, no special tools/syringes required.
Posted : 27/07/2015 5:41 pm
