Shorten travel on f...
[Closed] Shorten travel on floats ?
Anyone know if you can shorten travel of Fox float 32's (2009) ?
Can you DIY or do they have to go away ?
ta.
Posted : 01/06/2009 7:20 pm
I've not done an 09 but I don't see whey they should be any different from what's gone before. Spacers come in 20mm and 30mm so pretty much any reduction you want from 20mm to 130mm!!!!!!!!!!
Easy enough to do DIY. POp them open, snap the spacer on and fill 'em up with fresh oil.
Unless someone comes along and tells you the 09 is a total departure from what went before.
Posted : 01/06/2009 7:27 pm
Cheers. Where did you lay your hands on spacers ?
ta
Posted : 01/06/2009 7:31 pm
I went direct to Mojo for them.
Posted : 01/06/2009 7:39 pm
cheers.
Posted : 02/06/2009 6:43 pm
