Shock set-up help p...
[Closed] Shock set-up help please...
Bit of a suspension noob question here so please be gentle! 🙂
I’ve adjusted my rear shock (RS Monarch 3.1), to get a bit more movement out of it as it was running fairly stiffly before. It’s much better at soaking up hits now but the rear derailleur now bangs/grinds on the frame when the shock compresses.
Is it just a matter of adjusting the derailleur height to solve this, or is the shock working outside of its limits? Thanks!
Posted : 26/03/2010 6:17 pm
Shock should,nt be outside its limits.Unless there is a design fault.Try the Derailleur adjustment. what gearing do you have?Deores of old had this problem.
Posted : 26/03/2010 6:28 pm
Whoops...my mistake. I meant bottom of the front derailleur. 😳
Any ideas please.
Posted : 26/03/2010 8:27 pm
 mmb
try a small ajustment in derailleur height along with a small increase in shock pressure and rebound/damping adjustment if you have the facility on that shock.
Posted : 26/03/2010 8:42 pm
Thanks, I'll give it a go tomorrow.
Posted : 26/03/2010 10:02 pm
