I set my shocks up to sag about a quarter, but while riding I always bottom out
What pressures do you put in your shocks? I weigh 11stone and put in about 150 psi.
Posted : 14/02/2012 9:19 pm
It will vary according to fork, weight of rider etc.
I'd suggest doing it the opposite way around too. Put a cable tie on your fork (if its not got an O ring) and go ride on it. If your not using most of its travel then you have too much pressure in the fork (you shouldn't be bottoming out however). As a guide adjust the pressure until you only have about a quarter of the travel left unused.
Posted : 14/02/2012 9:29 pm
