Shock O-ring questi...
[Closed] Shock O-ring question
[#8046420]
With all the air out of the shock, should you be able to compress it enough to ease the O-ring off the shaft?? IMy RS Debonair plus fitted to a MK2 Nomad doesn't. It stops short of the end of the shaft by about 3-4mm.
Also seems the air pressure charts are miles out, I know they should be taken with a pinch of salt, but I've had to put in an extra 35psi.. It's all been set up as per the RS video a couple of times and coming to the same result. Maybe there is an issue with the shock (it's only 2weeks old) which will be a PITA
Carlos
Posted : 10/09/2016 9:17 am
You'll probably only knock the o ring off the shaft with a hard compression whilst on the bike.
Posted : 10/09/2016 9:47 am
You've still got a rubber bottom out bumper in there to compress
Posted : 10/09/2016 9:58 am
And with debonair you need to balance negative and positive pressure so don't just bump it up til you think the sag is right
Posted : 10/09/2016 10:19 am
Mk2 Nomad has a shock stroke of 2.5"
Just measure the distance from the Oring to the seal.
It may be that the shaft is longer than the stroke.
My Fox X2 has a 50mm stroke but a 57mm shaft. Makes it look like it's not getting full travel as the Oring never gets near the end of the shaft.
Posted : 10/09/2016 10:30 am
