Nowt fancy, to go on a 2005 Spesh FSR with Fox Triad.
Fox bushing is a standard DU bushing available from a local bearing factor or similar, the code you need to ask for is 08DU08
ta
I have been using [url= http://www.wychbearings.co.uk ]Wych Bearings[/url]
Decent service, cheap and speedy
eBay. Loads on there nice and cheap and delivered to your door. ๐
Polymer bushing from TF Tuned, BETD amongst others. Last longer than standard metal DU. Better still, use a better mount kit, like TF's Heavy Duty mount kit.
I got some posh ones from TF Tuned and slightly different posh ones from Jtech. They look cooler and they do seem longer lived. Any performance benefit is below my threshold of incompetence though
Would go with Fox low friction, small bump sensitivity is improved over their standard ones, breakaway force is considerably reduced.
dirtydog - Member
Its a bushing in the eyelet(s) of a shock.
