Shock bushing wear,...
[Closed] Shock bushing wear, ebay bushings?
Hello,
Had a bit of play around the shock on my Transition Bandit. I did ride for a little while with the play, without replacing the obushing straight away ( I know, never advisable).
I got some bushings on ebay for my Fox rp23 (on a transition bandit if it matters). Think I got a bag of 10 for 20 quid or so, - supposedly polymer bushings.
Straight after replacing, I've had no play whatsover. But after even just a couple of rides, I get play again.
Is this just a case of crap bushings? or possibly a sign of some other problems, or maybe an installation problem?
As I say, initially after replacement there is no play, - but it only takes a ride or two to see play again. Bushing does "seem" well tight in the shock eye after I replace.
Posted : 24/10/2014 8:01 am
Had the same with my B29 , bought the tool plus bushes from k-tec ,no problems since I fitted the polymer ones and its just had a week round the 7 stains with a clumsy oath on board .
Posted : 24/10/2014 8:18 am
Was it the k-tec bushings you had a problem with?
- Thats where I got mine too!
Tool seems to work ok for me (a bit of a pain the get the tool out after fitting the new bushing, but fine otherwise).
Posted : 24/10/2014 8:27 am
No the original factory ones just wore out the k-Tec were the replacement ones I fitted .no problems so far ,
Posted : 24/10/2014 8:33 am
