Shimano XT m785 ban...
[Closed] Shimano XT m785 banjo issue
[#4036095]
Hi,
I just bought a new hose for my XT brakes, I thought I could reuse the Banjo off the old hose but I cannot and there wasn't a new one in the hose kit, Very annoying! Does anyone know where to get one? its the 2012 XT brakes.
Thanks
Posted : 04/06/2012 12:25 pm
Aren't the Shimano banjo fittings crimped on? I thought you had to buy the right hose with one already fixed on one end, like [url= http://www.chainreactioncycles.com/Models.aspx?ModelID=67212 ]this[/url]
Or Goodridge seem to do a Shimano kit which has seperate banjo fittings [url= http://www.chainreactioncycles.com/Models.aspx?ModelID=4709 ]here[/url]
Posted : 04/06/2012 12:40 pm
I went goodridge when I swapped them to a new bike.
Posted : 04/06/2012 12:49 pm
I had the same problem, moving from xt765 to xt785 callipers. The banjo bolt is much longer on the 785s. You will need shimano SM-BH90 hose or equivalent.....
Posted : 04/06/2012 1:27 pm
^ you need to buy the hose with a pre-fitted banjo. Or go for a modular aftermarket set like goodridge or fibrax or Superstarcomponent.s
Posted : 04/06/2012 1:28 pm
 bbb
XT 765 needs standard BH63 hose or similar with pre crimped banjo and standard (gold) inserts.
XT 775 uses standard BH63 hose with no banjo - shroud nuts, olives and gold inserts at both ends.
XT 785 uses new BH90 hose with pre crimped banjo and new silver inserts.
HTH.
Posted : 04/06/2012 2:03 pm
Thanks, I bought the SM-BH90 hose kit with all the bits such as olives etc but the crimped banjo was missing off the end of the hose. I guess I should go back to the LBS to query it.
Posted : 05/06/2012 4:19 pm
