Shimano splined dis...
[Closed] Shimano splined discs - should there be any 'play' ?
The rear disc of my new Diverge has a tiny bit of movement when the rear brake is on. The front hasn't. I've taken it off and done the lock-ring up really quite tightly now and it still does it.
Is this OK ? This is my first bike with this sort of arrangement. Going to the shop with it takes a couple of hours out of the day which I haven't really got...
Thanks
Posted : 19/09/2015 10:41 am
I get a little bit of movement on mine. Its annoying, and one reason why normally Id prefer 6bolt.
Posted : 19/09/2015 10:45 am
I've got some 29er shimano wheels with them and I've got no play at all. Mine have some very thin large washers that help take up any play.
Posted : 19/09/2015 10:50 am
None at all on any I've owned/used/serviced.
Posted : 19/09/2015 10:53 am
Play on one of mine. Feels a bit like a loose headset when you squeeze the brake and rock it.
Posted : 19/09/2015 10:55 am
exactly ^ that
Posted : 19/09/2015 11:02 am
Sure it's the disc? Or the pads moving in the calliper...?
Posted : 19/09/2015 11:04 am
def the disc. It's the spline interface, sometimes if the hub/carrier havent been manufactured quite perfectly enough there's the tiniest of movements.
Posted : 19/09/2015 11:06 am
It was after moving the shims on the stem and re-tightening the headset that I discovered it.
Thanks, all. Up with it I will put...
Posted : 19/09/2015 11:22 am
Its quite common and well documented since the advent of centre lock.
One at uper tollerance and one at lower tollerance.
= movement folowed by wear, seems to get "so" bad then stops getting worse.
Preloading with washers makes no odds its a rotational play.
I hate it. I like my 6 bolts , far better design.
Posted : 19/09/2015 11:26 am
