Shimano gear cable ...
[Closed] Shimano gear cable with Sram Eagle?
Stupid and simple question no doubt, but, can you use Shimano gear cables (inner & outer) with Sram Eagle groupsets? LBS don't have Sram cables in stock and need one today.
Posted : 26/07/2018 12:38 pm
Yes, but make sure you get the Shimano 12 speed cable.
Posted : 26/07/2018 12:40 pm
It's what I'm running
Posted : 26/07/2018 12:42 pm
SRAM inner cables are narrower (1.1mm vs 1.2mm), but I suspect that if you replace both inner and outer together, it'll work just fine. If you tried to use a shimano inner in a 1.1mm sram outer, this might be another story...
Posted : 26/07/2018 1:04 pm
