Has anyone had issues with an xtr wheelset with centrelock setup:
xtr front wheel
centrelock
hope disk
rockshok SID fork
with this combo the disk runs SO tight to the fork leg that it misses by the width of a rizla
swapping to a shimano disk its all ok
I would prefer the hope disk for several reasons;
less squeal when wet
the shimano disk is 180mm and the hope disk mount is for 183, so i get a lip on the outside of the pad build up (another problem!)
it looks better
I could shim the outside of the disk but thats a crude solution, i'd lose it the first time i took the wheel off and the fork travel wouldn't be true either
Is there a 'slimline' setup that I could use cos I cant be the first to use this can I?
Andy
