Shimano cassette, C...
[Closed] Shimano cassette, Campag everything else?
[#5571011]
Can it be done? I hear there are spacing and width differences.
Posted : 03/10/2013 7:40 pm
Why?
I never understand the need to mix bits; if you've chosen Campag, go Campag.
Posted : 03/10/2013 7:41 pm
I'd have to buy campag wheels; one, I don't have the money and two the spoke pattern gives me the willies.
Posted : 03/10/2013 7:44 pm
 dobo
10 speed campag shifters work perfectly well with a shimano mech and an 8 speed cassette.
its what i got on the cx
and to answer crikey, cost, campag shifters were well cheap when i got them and had the mech off an mtb and used a silly cheap 8 speed cassette of a crc flood sale. campag shifters are better imo and rebuildable.
Posted : 03/10/2013 7:48 pm
Um, ok.
I've always used Shimano precisely because I don't want any issues. Campag anything is a deal breaker for me.
Posted : 03/10/2013 7:50 pm
Go and ask on the CTC forum.
You'll get pointed to a million Shimergo threads. You have done what I did, mainly because used Shimano spec wheels are cheap.
I used a 10 speed Campag set up with a normal 105 cassette. pretty well ok.
Thought I would be fussy and acquired an near new America Classic cassette which had Campag spacings with Shimano splines. Much better.
You can get the same by Ambrosio, which I now use or possibly Miche as well. perfect indexing. Job done.
Alternatively buy my Campag Record/mavic rim wheels for bugger all.
Posted : 03/10/2013 10:18 pm
I use campag cranks, Shimano chain and cassette with MicroShift shifter and mechs. Doesn't answer your question but just saying like...
Posted : 03/10/2013 10:25 pm
I have some retro Campagnolo Zonda wheels (Campag cassette) running old style (grey post 600) Ultegra rear mech and new Sora STI levers. It shifts like a dream.
There is a website (I have had a quick scan and I cannot find it) that has some compatibility charts on it.
Posted : 03/10/2013 10:39 pm
I ran exactly this for a while, but found some of the gear combos a bit grumbly.
Ended up sticking a shimano crankset ( tiagra) and chain on.
Still have the campy shifters and mechs. This seems fine.
Posted : 03/10/2013 10:42 pm
 Kuco
If you want to keep it 10 speed then [url= http://www.on-one.co.uk/i/q/CAAB10S/ambrosio_10_spd_cassette ]one of these.[/url]
Posted : 03/10/2013 10:45 pm
 dobo
I never even knew those Ambrosio 10 Spd Cassette existed. Thanks
not that id go that route probably as id have to buy a campag mech and the 10 spd amrosia is more expensive than my sram 8 speed and doesnt really offer any benefit, wonder what the weight is for the 12-28t?
just what the op is looking for though i recon.
Posted : 03/10/2013 11:00 pm
 mrmo
What wheels do you have? Depending just get a new freehub body.
as for compatibility, yes no maybe, depends if it is 8/9/10/11 different answers for each.
Posted : 03/10/2013 11:44 pm
Hi,
The Ambrosio cassettes are good and do the job.
Once you have one and it wears out you can then just use the spacers on any Shimano cassette.
Regards
Posted : 03/10/2013 11:46 pm
 mboy
Shimano Cassettes generally have the largest 3 or 4 cogs on a spider, so you can't fit them individually with a different spacer.
Nice thought though!
Posted : 04/10/2013 12:32 am
 Sam
Mattsccm - could be interested in your wheels!
Posted : 04/10/2013 1:32 am
Harder to find than it used to be, but here's the CTC Shimergo article
http://www.ctc.org.uk/cyclists-library/components/transmission-gears/derailleur-gears/shimergo
Posted : 04/10/2013 2:46 am
I run 9 speed ergo & mech with shimano 9s cassette ok, also 9s ergo, shimano mech and 8s shimano cassette ok.
LOLercrafts at crikey asking the same question every time this comes up.
Posted : 04/10/2013 6:24 am
