Shimano brake lever...
[Closed] Shimano brake lever / caliper compatibility
[#4726513]
Hi
Are Shimano levers / calipers all compatible. i have some M775 levers (not the latest model) and latest XTR calipers bought on a whim from a big pile of close out bits at lbs - assume they will work together?
thanks
Posted : 08/01/2013 10:25 am
Yep. You will need to use SM-BH90 hose with the long banjo bolt to join the levers to callipers.
Posted : 08/01/2013 10:40 am
thx
oh bollox.......... not quite the bargain I thought then! May take 'em back
Posted : 08/01/2013 11:19 am
Mister P
Is it just the banjo fitting which is differenct? or anything else?
thanks
charlie
Posted : 08/01/2013 1:35 pm
