Shimano brake bleed...
[Closed] Shimano brake bleeding quick Q
[#4417824]
The hose you need: what diameter? I understand that windscreen washer hose is fine but it appears to come in different diameters.
Posted : 01/10/2012 3:29 pm
I used 3mm from B&Q - good tight fit onto the syringe and the bleed nipple.
Posted : 01/10/2012 9:18 pm
Stuff that comes in the Shimano kit is 4mm ID.
Posted : 02/10/2012 8:35 am
Aquarium air filter hose from Pets at Home will work
Posted : 02/10/2012 3:33 pm
Found the 4mm stuff in the Shimano bleed kit a bit loose.
Also, what's that bit of black plastic which comes with the official kit?
Posted : 02/10/2012 3:34 pm
It clips the hose onto the bleed nipple. You push the hose onto the nipple then push the black bit down over the nipple. It works a treat. I find putting a small zip tie around the hose and syringe nozzle helps keep it in place at that end too. You can give a good push on the syringe without risking squirting fluid everywhere.
Posted : 02/10/2012 3:43 pm
I feel like a right numpty. And have had oil squirt everywhere at both ends before. Can you use the black plastic bit to undo the bleed nipple too instead of a 6mm spanner?
Posted : 02/10/2012 4:23 pm
er, ah, oh.... 😳
Posted : 02/10/2012 4:24 pm
