I’m looking to change a twist shifter to a trigger shifter. I have an sram x9 9 speed derailleur, will any sram 9 speed trigger shifter be compatible and will I need to change the cable? Any and all advice will be greatly appreciated.
Posted : 20/10/2019 5:26 pm
Any 9 speed sram shifter should be compatible. You'll need to change the inner cable and could be worth changing the outer whilst your at it if its getting on a bit.
Posted : 20/10/2019 5:35 pm
Thanks for the reply👍🏻
Posted : 20/10/2019 6:53 pm
