Sheared bolt remova...
[Closed] Sheared bolt removal advice
 jonb
[#1055459]
The bolt that holds on the mudguards and rack on my inbred commuter has sheered. It's left the body of the bolt flush so I can't get it out easily.
Any suggestions? I don't own any power tools and it's a hack bike (£60 frame) so I'd like to keep the costs low rather than spending money on tools that are worth more than the frame.
Posted : 19/11/2009 6:53 pm
Is any of the bolt visible on the back? Grab it with pliers if so
If not sometimes using a punch at a tangent on the outer edge of the bolt and tapping it round works.
Really you need to drill it tho if its sheared
Posted : 19/11/2009 7:06 pm
No power tools you say - you're pretty much buggerd then.
Got any mates who atleast have a battery drill and some HSS drill bits?
File a notch into what you can see with a needle file, then insert screwdriver/punch. You'll be there hours, easier to pop round a mates who has a drill, drill out the bolt shaft to just less than the diameter of the thread and then chase the thread out. or drill the whooething out and araldite a new bolt in to hold the 'guard. Its only a hack afterall.
Posted : 19/11/2009 7:12 pm
 jonb
Tried the file, I think it's a steel bolt (in a steel frame) so it's stuck. Think I'll find a drill and use a nut and bolt to hold it together afterwards. But for tomorrow I'll just add more cable ties to the ones that are holding everything else together.
Posted : 19/11/2009 7:15 pm
If you drill it with a small drill you should be able to get enough grip with something such a s a torx bit to get the stub out without ruining th threads - there is a fair chance that the drill will actually push the stub of the bolt out
Posted : 19/11/2009 7:18 pm
