Setting sag and rea...
[Closed] Setting sag and rear suspension stiction
[#4193196]
After reading the Race Tech Motorcycle Suspension Bible I decided to try the following method of setting sag on my Santa Cruz Nomad
http://www.triumphnet.com/st/acc/racetech/setup.htm
I got quite a large variation with 36% sag on one measurement and 20% on the other.
I have just changed all the bearings and installed a new shock (Rock Shox Vivid coil) so I'm wondering if I should just ride it for a while to let everything bed in or start stripping it down to see if I can find anything wrong.
Or are these normal numbers for a mountain bike?
Posted : 25/07/2012 8:13 am
Those numbers seem a bit high, unless your riding a 10 inch DH bike.
Anything else Id go for between 15-20%. Get a mate to measure it while your sat in a normal riding position. Measure it a few times.
Posted : 25/07/2012 8:41 am
I'm aiming for around 30%. What I'm asking is how much stiction is normal for a full suspension frame.
Posted : 25/07/2012 8:48 am
is 35% L2 & 20% L3?
Then yes you have lots and lots of friction/stiction in the system.
Do as you sugest and run it a bit, or just pop the shock out and check the linkages are free.
Posted : 25/07/2012 8:50 am
Almost none in the frame links, a bit on the shock.
I find the massive difference you have at odds, its just one relatively small shock with lots of leverage and a bloke sat on it, for an MTB I would expect L2 & L3 to be the same every time.
Posted : 25/07/2012 8:54 am
Yeah, it's new bushings on the shock but I've got a feeling that it's the linkages that are the problem. There shouldn't be any bed in time for new bearings I would have thought?
Posted : 25/07/2012 8:58 am
