I'm about to attempt to change the oil in my forks give them a good clean up. Theory are Marzocchi z150's, I looked on a forum guide on how to do them and they say to use 7.5wt oil, would I be able to get away using 10wt? Have soon in the garage 🙂
In the summer (Ha) you might, but in the cold of winter your damping maybe a bit sluggish 8)
Give it a go. I doubt you'll notice any difference to be honest. All you need to do is back the damping off a bit to compensate if you do. 🙂
No way of knowing. Two different brands listed as 7.5wt would have different viscosity ratings. Oil wt means nothing really. Try if, if you like it, great, if not, try something else.
PeterPoddy - Member
This covers it really. A bit less compression and a bit less rebound and you should be fine. Worst case scenario would be spiking, and you'll know if that happens!
Just curious. What is spiking?
Too much/too heavy an oil trying to flow through the damper can effectively lock it out (especially on square edged hits in my experience). Last time I had it was when I was playing with the compression on my old 888s, not a nice sensation when it kicked in over braking bumps
When the damping is too slow and the fork feels very harsh when you hit a series of fast bumps
GHB best I find 😉
