Hey
Looking for a bit of advice.
A frame I'm looking to buy as a crease on the seat tube / down tube near the purpose made cut. The previous owner ran a 29mm seatpost in a 30mm down tube and appears to have crushed the tube ever so slightly.
If I buy i'm looking to run with a 30mm shim and 27.2 grav dropper.
Question is ... is this frame knackered and unsafe and will the crease crack ... or is this pretty superficial?
Thanks in advance
Avoid.
Avoid unless you can buy it for £5 or less n
as above - doubts about a 2nd hand buy? walk away every time
Aluminium ?
It will almost certainly crack at the crease.
it's aluminium ... a cove stiffee
Avoid and tell the owner he is a tard.
you guys are the best ... orange crush 2011 it is then
