Screw extractors - ...
[Closed] Screw extractors - which type is better?
 JoeG
Dad broke a hex key and further mangled a hex socket head bolt. I tried the hammered in torx bit, but that didn't work. The screw is in a recess and can't use pliers or anything to grip on the outside. So a screw extractor is needed IMO. But which type is better?
[url= http://www.lowes.com/ProductDisplay?partNumber=445713-48246-KDT720&langId=-1&storeId=10151&productId=4731439&catalogId=10051&cmRelshp=req&rel=nofollow&cId=PDIO1 ]Straight fluted[/url]
or
[url= http://www.lowes.com/ProductDisplay?partNumber=445713-48246-KDT2419&langId=-1&storeId=10151&productId=4731419&catalogId=10051&cmRelshp=req&rel=nofollow&cId=PDIO1 ]Spiral fluted[/url]
Posted : 24/09/2015 2:26 am
Never seent eh top ones before, looks like they will do much the same as the lower ones.
The ones I used most were like this:[img] [/img]
Posted : 24/09/2015 3:08 am
Joe, usually the best solution I've found is to hammer the hex key back in and then weld it to the head of bolt, it will usually come undone.
Posted : 24/09/2015 5:02 am
Straight flutes are for soft materials
Spirals are for hard metals
I prefer http://www.irwin.com/tools/screw-bolt-extractors/hex-head-multi-spline-screw-extractors-532-series-plastic-case-sets for my spirals - they just work.(pst hanson - invented the screw extractor in the 1940s. - and snap on even rebadge this set;))
Left hand drill bits are the way forward for drilling the hole - often this removes the offending item. If not you have a nice hole for the extractor to work in.
Top tip, buy good quality ones , dont force em, having had to pay to get a colleagues hamfistedness spark eroded out (a drill bit wont touch the hardened steel (cheaply hardened on cheap tools hence they go brittle and snap easier)
Posted : 24/09/2015 6:17 am
Spiral is the type I've got and used successfully. There didn't seem to be any other option in the shop when I looked.
I had to drill pilot holes though for these to bite. Had to use Cobalt bit as the bolt was stainless steel and HSS bit I had was going nowhere. HSS can be used for softer bolts apparently. Small hole, give it a try, then bit bigger, try again etc.
It might just rattle out with drilling anyway.
Posted : 24/09/2015 8:32 am
 JoeG
Thanks, everyone. I think I'm going to get [url= http://www.irwin.com/tools/screw-bolt-extractors/10-pc-spiral-extractor-drill-bit-combo-pack ]this set.[/url] It looks like the drill bits are regular right hand spiral, though...
Posted : 25/09/2015 2:17 am
After getting through a few admittedly cheaper long spiral ones I got some of the stubby ones linked to above by trail rat and they have been so much better.
The drill bits will be a normal twist , just drill a hole of the right size gently tap the extractor in square and then turn the extractor left. Slow and steady
Posted : 25/09/2015 6:32 am
