Save me from madnes...
Save me from madness…SS MTB frame…
@legometeorology thankyou for finding that frame again, agreed, out and out bargain but I’m hesitant as there’s a niggle that inside that wonders if I’ll only end up swapping it later due to the, as I understand, max 2.2 tyre clearance on 27.5 wheels, again, probably me being unnecessarily picky
Posted : 27/09/2022 12:14 pm
@thisisnotaspoon thanks for sharing your thoughts on chain devices / tensioners, makes a lot of sense and quite helpful
I don’t have one yet, was more of a “I found so could use this” idea
Posted : 27/09/2022 12:16 pm
Still watching that longitude on the ‘bay hoping someone buys my ss road bike before it goes
Posted : 27/09/2022 12:17 pm
@donslow
Totally understand, that's why I've moved away from trying to repurpose a 26er frame, as I'm sure I'll just end up wanting to run a larger 650b tyre or a decent size 700c gravel tyre
What I really want is a nice 650b frame with sliding dropouts, like the old Pipedream Sirius or Kona Explosive
Posted : 27/09/2022 12:52 pm
@legometeorology snap! Since starting this thread I’ve done a fair bit of searching / reading with a bit more knowledge of what I’m after
Think you’ve nailed it really
Nice frame
Disc brakes
Sliding dropouts
Enough room for a decent pair of 27.5 tyres
Job jobbed
Posted : 27/09/2022 1:58 pm
Someone I know(Moi) has a med genisis IO frame with a very nice dt swiss fork taking up space😉😉🤦🏼‍♂️
Posted : 27/09/2022 6:39 pm
Someone been reading my mind. I have regreted selling my IO a couple of years and want to replace it. Maybe somethng a bit more modern for 6650b wheels though but importantly not something to slow handling. I am a bit of adinosuar regarding MTBs but find that modern full suss things handle like Peter Fondas Harley. I want something nippy and sharp not a barge. Thoughts anyone.
Posted : 27/09/2022 6:56 pm
@sparkyrhino nicely stealthed ha ha I’d have been tempted but alas…
A) medium will be too big for me
B) I think I’d want bigger than 2.2 27.5 tyres, I’m also assuming the fork is for 26er also?!
@mattsccm unfortunately I’m not the one to be able to offer any valuable advice but hopefully someone with better knowledge than I will be along shortly…
Posted : 27/09/2022 9:09 pm
Stealth add, me, never. Fork is 26 but takes 27.5👍🏼😉
Posted : 27/09/2022 9:51 pm
How about trying half link chain?
Posted : 28/09/2022 8:24 am
My 2p
I had a Pipedream I bought to build a SS around and it was great. A geared Ti456 was my "big" bike.
Years later I have a FS as my "big" bike and the Ti456 is SS with a tensioner. I've also run other frames as SS with a tensioner and would say they're overall, maybe easier than a "better" frame, with sliding dropouts, EBB or anything else. Sure it might be a little tricky getting the wheel out, but how often does one get a puncture these days? A sprung tensioner will keep tension even when the chain wears, where my commuter gets loose and wobbly until it drops and I think "oh yeah I should adjust that"
TLDR; get the frame you want and put a tensioner on.
Posted : 28/09/2022 10:30 am
I found my blackspire style device much quieter than a sprung version. A bit more fiddly to set up but once it's on its easy to adjust. I can't hear it at all while riding. My old sprung hanger tensioner drove me mad with the noise.
Posted : 28/09/2022 11:10 am
https://ridefarr.co.uk/products/farr-atb-frame-kit?variant=40422944997537
Great VFM at £250. Looks a tad steep but can't be sure w/o the fork length on the diagram. 69.5 deg if sagged on a 29er's ok, a quick-handling XC SS is no bad thing.
SS
Posted : 30/09/2022 8:32 am
damn that's stupidly cheap
Posted : 30/09/2022 11:33 am
Have since been doing a fair bit of searching about and am currently keeping an eye on
2016 (?!) Genesis longitude with forks
Or
Kona unit 29er without forks
Genesis would work out around £40-£50 more after shipping
This build is going to be a slow one with bits to build it up bought on a monthly basis
Opinions please all?! What would the STW hive go for out of the two?!
Posted : 01/10/2022 11:20 pm
Whilst I await a reply from the kona seller
Does anyone know if a 2006 unit frame will take suspension forks up front?
https://m.pinkbike.com/buysell/3288628/
Posted : 02/10/2022 12:28 am
Google images suggest the 2006 Unit was designed around a short travel sus fork. Tbh though, that's not a great deal for such an old frame, in my opinion anyway
I doubt they'll be much difference between the 2016 Longitude or a Unit of roughly the same era (or older), although the latest Unit's are a much more low-long-slack modern geometry (although I'm not convinced that's all a good idea for a rigid build)
This is an obvious suggestion, but is the horizontal-dropout On One Inbred on your list? Those come up reasonably often and quite cheap
The old Genesis Latitude Alfine frame was damn nice too, but rare now
https://singletrackworld.com/forum/topic/in-need-of-inspiration-show-me-your-genesis-high-latitude/
Posted : 02/10/2022 1:40 pm
 Bazz
They sure do, I had one many years ago, my first 29er I think, that I ran with a 100mm Rockshox Tora. One of the few frames that I regret selling, really nice bikes.
Posted : 02/10/2022 1:47 pm
Thanks for the replies all
I have been looking out for an inbred (and many others) too but not coming up for sale in a small very often
Both the genesis and kona seem to be reasonably highly regarded frames, still undecided which to plump for, on a flip side, the genesis comes with forks already which would make the build a little quicker for now but the kona is 29er specific which would allow for wider tyres than if I put 29ers on the genesis (I’m guessing here)
I guess a lot of my current deliberation comes down to the fact the genesis auction ends tonight and am a little reluctant to let a potentially good deal slip by
Posted : 02/10/2022 2:01 pm
 Bazz
As much as I regret selling my Kona Unit, I'm not sure £220 for a frame that's getting close to 20 years old constitutes a good deal, seems a bit steep to me.
Posted : 02/10/2022 2:27 pm
Tis a fair point @bazz
I’ll be honest, I’m not often sure what is a good or not so good deal for bike frames, I always kind of figure, if I’d be happy paying that amount, it’s not a terrible deal, I think the genesis is still a forerunner for now u less I find something betterer before tonight’s auction ends
If anyone has any suggestions or has their google-fu skills honed in today, any finds or suggestions would be greatly appreciated
Posted : 02/10/2022 2:41 pm
@donslow
It was bad timing, but a day before I saw this thread, there was a small 2011 Unit frame + fork on ebay for £125 buy-it-now. So I think that 2006 one is way overpriced, but the Genesis is currently a bargin. Also, I would have thought 29er clearance would still be good on the Genesis with the wheel set back in the dropouts
Posted : 02/10/2022 3:46 pm
This is almost certainly gone, but that would have been well worth it
https://www.pinkbike.com/buysell/3337833/
Posted : 02/10/2022 3:50 pm
@legometeorology that sir is a good find! Thankyou
Have sent the seller a message because…well, you never know
Posted : 02/10/2022 4:26 pm
Apologies for continually bringing this up…
Still watching the longitude on eBay which I really like but have just found this which has piqued my interest a fair bit
https://www.ebay.co.uk/itm/195371793093?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=n_zsTxBcQva&sssrc=2349624&ssuid=Is4lULm9TOW&var=&widget_ver=artemis&media=COPY
-Designed for 26er but enough room (apparently) for 27.5 x 2.8
-100mm suspension fork compatible,
-Disc brakes
Price SEEMS reasonable
I like the look of it a lot, This could well be my new single speed project / build
I’m struggling to find a bad point, have I missed something?!
Anyone have any experience / comments / suggestions?!
Posted : 04/10/2022 8:51 pm
Surly frames, I think, are renowned for being a bit heavy. But they’re well made, last a long time and for the price that looks like a great little frame and fork, you could do a lot worse than that.
Posted : 04/10/2022 9:33 pm
@tuboflard largely what I suspected so that was all the confirmation I needed, many thanks
It’s got to be the one I think, pretty much the first frame I’ve seen since looking that had got me genuinely excited
Posted : 04/10/2022 9:37 pm
What's the current tensioner of choice?
Posted : 04/10/2022 11:46 pm
Currently considering the surly tugnut or something similar
This is going to be a (largely) slow build with getting a couple of bits a month until it’s rideable so if it takes a while to work out the tensioner situation it’s no real delay to overall progress
Posted : 05/10/2022 12:11 am
If you go for the Surly, post some pictures up of the build when you’re done!
Posted : 05/10/2022 8:32 am
Bought the surly!
Will be a couple of months or so (probably not this side of Christmas) but definitely expect pictures, a barrage of “wanted” ads and even more “help! How’s does this work / fit together / is this part right?” Posts ha ha
Thanks all for the replies and help…so far…
Posted : 05/10/2022 8:53 am
Page 2 / 2
