Am coming up to ride in the Peaks next weekend and some one mentioned a rumour that some of the trails around Derwent had been sanitised with HArdcore so just trying to find out so can plan ride accordingly...
Thanks in advance :O)
a bit of the trail from Lockerbrook into Ouzeldon Clough has been flattened
that's all i'm aware of
It's just bits and bobs, nothing major enough to justify re-routing owt.
The downhill to the Hagg Side car park has been resurfaced, and is now a gravelly fireroad affair. Hopefully this will return to its former glory after a winters use.
Over towards edale, the singletrack on the side of mam tor has been widened and flattened out, and also the short climb to rushup edge.
Thats all I know of...?
Thanks for that lookslike i'll carry on as i was nothing too much seems to have changed.
:O)
The bottom of the screaming mile has been covered in loose stone and it ****in scary when you hit it at 30mph+.
Yeah, I forgot about that. It's a vile climb as well now, very easy to spin out at the bottom.
