Sanderson Frame siz...
[Closed] Sanderson Frame sizing
I'm looking at getting either a Breath of Life frame but I'm not sure on sizing. At 5' 10" with a 32" inside leg I currently ride a 16" 456 which is a perfect fit.
I've phoned a couple of bike shops and one said 16 the other 18 just to confuse the issue.
I would also be interested to know if there were any changes to the frame between the current models and last years models.
Posted : 29/04/2010 9:11 am
I have a Soloist in 18" an am your height, i wouldn't want it any smaller.
Posted : 29/04/2010 9:14 am
Depends on your riding, theyr ever so slightly longer than inbreds IIRC.
I'm building an 18" with a 110mm stem for all day XC and I'm just shy of 6ft but wear 32" trousers and have a preferance for longer bikes.
I'm 5'8" and I had a 16in Sanderson. IIRC they are a tad longer (1/2 inch?) than an Inbred. They are certainly loooong bikes, put it that way!
If you're on a 16in Inbred, a 16in Sanderson will be spot on.
I did say they're long didn't I? Yes. They ARE long. ๐Ÿ™‚
EDIT
Basically, you're 2 inches taller than me, and I've got a 30in inside leg, so it's all in your legs. 16in. You don't need it any longer. ๐Ÿ™‚
I am 5'11" and have 33" indside leg. I liked my mate's 16" 456 with a short stem and looooong inline seatpost, its a 'fun' rather than efficient riding position. I also ride an 18" soloist with a 100mm stem and 350mm post all the way out which is much more 'xc' but just right. I wouldn't want a 16". I suppose i would be wary of seatpost length if you went for a 16" sanderson: if you are proportioned like me you will need a 400mm post about an inch away from max.
Posted : 29/04/2010 9:19 am
Thanks for the responses gents very prompt.
So to summarise, get one of each just in case ๐Ÿ™‚
Riding will be predominantly XC, Woburn sort of stuff up to 4 hours in the saddle.
The On-one has a 50mm stem with a straight post. I had a Cotic medium frame that pushed me further forward than the 456, but fitted equally as well.
Posted : 29/04/2010 9:26 am
get the 18.
I'm 5ft 7in and ride the 16in soloist. I also had a 16in 456.
Tho. you find the 16in 456 fine - that would be due to the 456 super long top tube. The soloist is about an inch shorter in that measurement.
Posted : 29/04/2010 9:29 am
๐Ÿ˜† that's the way its looking isn't it! Perhaps best to try a couple. IIRC the geometry is the same on the breath, life and soloist so you don't have to be fussy which ones you have a go on. I'm in deepest devon with an 18" if that helps.
Posted : 29/04/2010 9:34 am
A short 6ft here. I've been running a 16inch 456 for a couple of years as a 'woods play bike' but its actually morphed into my main ride for the last year.
As I've got fitter and the mileage has gone up, I've realised its a bit too short for the longer rides. I'm also right at the limit of a 410mm seatpost. I'd get an 18 next time.
Having looked at the specs, the 456 and Sanderson are the same length.
Posted : 29/04/2010 9:41 am
I've just looked up the specs -
456 (ACTUAL TOP-TUBE)
16 - 584mm
18 - 597mm
Life/Breath (ACTUAL TOP-TUBE)
16 - 584mm
18 - 597mm
Soloist (ACTUAL TOP-TUBE)
16 - 559mm
18 - 572mm
Yep, that's not a missprint, a 456 is [u]identical[/u] in length to a Life/Breath ๐Ÿ™‚
So, if you like your 16in 456, a 16 in Life/Breath will be spot on, but you'll need an 18in Soloist.
Confusion sorted. ๐Ÿ™‚
Posted : 29/04/2010 9:44 am
