Salsa anything cage...
[Closed] Salsa anything cages
[#4706192]
Read that they break quite easily issues being that they seem to crack anybody have experience of this?
Posted : 02/01/2013 9:35 pm
got some on order so hope not,
But I suppose it depends on how much weight your going to put in them.
Posted : 02/01/2013 9:36 pm
There does seem to have been a number of failures. I don't know if they are related to over-loading, poor fitting, not using all the cage mounts or just poor manufacture/design.
Posted : 02/01/2013 9:37 pm
 doh
mine cracked at the welds on the tabs. it had a <kilo sleeping bag in it for a few hours there and back on an overnighter.
even cheapy bottle cages hold water bottles with about the same weight for years with no issues.
apart from that very good 🙄
Posted : 02/01/2013 9:45 pm
doh - was it mounted with all three tabs?
Posted : 02/01/2013 9:47 pm
 doh
2 tabs and hose clamps as per salsa instructions for if you dont have the 3 mounts.
Posted : 02/01/2013 9:53 pm
Even when mounted properly, using all 3 mounts on Salsa forks and keeping the weight below 5lb (as Salsa say) they still snap ... there's a weak point as doh points out, they all go in the same place.
Posted : 02/01/2013 10:04 pm
[IMG] http://i1242.photobucket.com/albums/gg535/basil179/iphonedump15-07-12275_zpsd31a2a21.jp g" target="_blank">http://i1242.photobucket.com/albums/gg535/basil179/iphonedump15-07-12275_zpsd31a2a21.jp g"/> [/IMG][/img]
Er I wouldn't bother!
Thermarest prolite on one side ,Snugpak on otherside. 2nd tour ****ers tried to kill me and broke me spokes in nowhere Scotland
Hmm. Might work by using the strap around the fork too - not that you should have to!
Edit: Basil - What did ISON/Salsa have to say about that?
Posted : 02/01/2013 10:05 pm
My alu bottle cages always break over time.
No way would I trust that cage with something heavier in it without strapping to the fork!
easy to say with hindsight of course.
Posted : 02/01/2013 10:11 pm
When we did this in July. Charlie posted he had sold hundreds without issue, and another member posted there was a steel version in development due to "problems"
200 yards after screaming down a big hill to have one side pop into the wheel and the other side on examination to be cracked at all three tabs I have not replaced them again.
I now put bottle cages on the forks and Santa has brought me an Alpkit Stingray
Oh dear. I've got a pair on order. I'll keep the loads light then. If its not salsa stems or racks its their cages cracking....
Posted : 02/01/2013 10:13 pm
 Nick
Just a poor design, mine are both cracked but as yet still holding on, I shan't be using them again that's for sure.
Can't for the life of me understand why Salsa designed them like that, trying to combine the strap guide with the mounting plate is just silly, and they are still selling them!
Yep, that is what I will be doing I think, although I'll probably make a full frame bag to replace the one I made that still allows for a bottle cage inside the front triangle.
How heavy do you think a Thermarest Prolite Is??!!! 😯
Posted : 02/01/2013 10:15 pm
 Nick
They are easily knocked about, the bike falling over may well have accelerated the damage to mine but I've heard too many stories to have much optimism that even with care they will last.
Posted : 02/01/2013 10:17 pm
Okey doke cheers for the info chaps and good pictures too. Don't think ill be bothering then this time !
Posted : 02/01/2013 11:02 pm
Paid for mine, but using on a fargo fork so will strap it up and see what happens,
good job i have a minimalist rack to share the weight on the front end 😐
Posted : 03/01/2013 8:37 am
My second set have faired better than the first. I think that ditching the Salsa straps and knocking up some shockcord ones has helped ... it's very easy to put a lot of sideways pull on the cages with normal straps and besides, the standard straps are a bit too short and fiddly with cold hands 😉
Posted : 03/01/2013 10:07 am
Unfortunately for Salsa that looks like an opportunity for someone to jump in and make a much better one there. Good case of great idea, piss-poor implementation.
Posted : 03/01/2013 10:15 am
Have a look at bikebuddy.co.uk
These guys have been making something similar for almost 30yrs
Posted : 03/01/2013 11:23 am
