Rusty chain
[Closed] Rusty chain
 kevj
[#3502818]
So after a ride out the other day I didn't have the time to clean the bike or lube the chain.
Today, the chain is a nasty brown colour and a few links are quite stiff.
Any recommendations for a good treatment? Or is it good old stiff brush and three in one oil bath overnight?
Posted : 29/12/2011 5:54 pm
Sometimes it works, sometimes it is just too far gone.
Last December I was up in the lakes for 3 days in snow and put the bike on top of the car to come back down the M6 in the snow and salt.
Soon after I took the chain off (without properly oiling it) and when I got it out a few months later it was just a solid thing and wouldn't recover no matter what I did. Skippety skippety etc.
I threw it away, which hurt, as it was a Yumea.
Posted : 29/12/2011 6:03 pm
I've had some success with a wire brush and a good scrub of degreaser outside before now after previous "too much post-ride ale to be bothered to spray GT80" incidents.
This will only sort out the outside and the oil bath's a good idea but unless you've let it go too far then usually the following ride and clean-cycle will sort out the innards of the chain and it'll work fine.
Posted : 29/12/2011 6:05 pm
 kevj
Luckily, it appears only to be surface rust so hopefully a good clean and oiling should suffice.
Other than being arsed to do it properly, any good lube out there other than finish line wet or dry?
Posted : 29/12/2011 6:10 pm
Scrub clean with wire brush, soak in diesel/degreaser, dry, soak in 3in1, wipe excess off, ride, clean and lube as normal. Brought a well siezed chain back before for me.
Purple Extreme lube gets my vote
Posted : 29/12/2011 6:21 pm
