running swampthings...
[Closed] running swampthings tubeless
[#3877897]
as above really, thinking of running a wire swampy tubeless on a stans crest rim. is it likely to seal? it'd be nice to be putting them away but no chance round here at the mo looking at the forecast
Posted : 16/04/2012 6:08 pm
Mine worked really well (2.35 wire singleply) Still weren't very good tyres mind but they sealed lovely.
Posted : 16/04/2012 6:09 pm
same tyre, cool. I rate em, there's lots of roots round here and tyres like the trailraker get a bit nervous on them I reckon
Posted : 16/04/2012 6:22 pm
 Taff
Yes they seal fine.
Posted : 16/04/2012 6:24 pm
WORKED FINE ON MY 819s.
Posted : 16/04/2012 6:28 pm
much appreciated all. I'm doing the gravity enduro in the fod Sunday & thought I'd put some proper rubber on the bike as it's looking pretty wet
Posted : 16/04/2012 6:38 pm
Worked very, very well on my 819/823's. 2.35 st. Sealed with a hand pump. Tyres are amazing if it's wet and slippy, like someone's walking ahead of you drying the trail. They are draggy as anything though.
Posted : 16/04/2012 6:56 pm
they're not the fastest, but I'll only be running one on the front. I'll happily sacrifice some climbing speed for grip on the downs
Posted : 16/04/2012 6:58 pm
Great for confidence IMO, tubeless on Stans works fine. Bit heavy/draggy to pedal on the back [esp the supertacky] so you're probably right to just do the front. Of course, though, the rear does have some work to do, so you'll also want a decent grippy tyre for the climbs and off cambers. I never really liked the Trailrakers.
Got an old Conti Vertical pro, not a bad rear as long as it's not too sticky? Otherwise the Bonti Mud is good, but narrow / low volume.
Posted : 16/04/2012 8:12 pm
Conti's Baron is miles better IMO- works almost as well in pure slop, and it's better at everything else. Miles better on hard stuff, and not as draggy either. DOwnsides are that they're expensive, and a bit of a sod to get them to seal up tubeless!
Posted : 16/04/2012 8:25 pm
I found the 42a version fairly tiresome to tubeless and the 60a one impossible, on Flows. What's this about wet at FoD? It's like a desert over here! I was expecting loose fast trails...
Posted : 16/04/2012 8:40 pm
