Goo evening, after pedaling up glentress black great fun ive got my runners knee back Iliotibial Band absolutly kills, has any one else had this and any tips to getting it feeling better and preventing it in future.
roam roller.strengthen hip flexer and glutes
Gottle 'o geer, gottle 'o geer,
do you spin easy gears?
or push big gears?
have you checked your saddle height recently?
I used a foam roller to relieve tension in my IT Band and I do tretches every day. Two of them are in [url=
video[/url] and I do a third stretch as well which involves standing with crossed legs and bending sideways. These were recommended to me by my physio.
I also adjusted my saddle forward as I was extending my leg slightly forward on the downstroke.
Otherwise rest it, take pressure off it when walking up and down stairs, when standing up etc. Rest it until you can walk up and down stairs without any hint of trouble and then give it another week before heading out on your bike.
ITB is a bugger, but it's fixable.
Foam roller/ rolling pin - lie on it so the painful thigh is on it, and move yourself so you roll up and down it. It's a good way of massaging the muscle and loosening the knots.
Stretches: face a bed, pull your sore leg up, knee bent. Then lean onto it, so you're stretching the outside of that thigh.
And strengthening: stand on the sore leg, with your other leg up (ie standing on one leg). Bend the knee you're standing on, and slowly lower and raise yourself on it.
Do those every evening, regularly, and you should start to see some improvement in a couple of weeks or so.
+1 for saddle height.
Cheers, only ever had it from running last year before, saddle height is a bit difficult to judge as i move it up and down all the time,
Ill try these exercises and get a foam roller. guess its a couple of weeks off bike.
parling - Member
Sounds top candidate for the problem?
cynic it could have been but never got it from climbing on a bike, saddle has to come down for hills other wise it tries to violate me, then i forget how high it was up. I ride quite a lot so its a tad annoying might move my saddle forward and try that once pains gone down.
+ 1 Nicko
Here you go
This i what you want to do, it is the magic bullet!
Do the second exercise, where he has the one leg, in front of him, and he bends over towards it.
It will stretch your big mucsles from the upper leg, it will hurt a bit, but thats a sign, you are doing it right!
do it 2-3 x times a day, for a couple of minutes
You can also do the exercise standing leaning over fx a kitchen table.
