Hi all, the rebound adjustment on my 2022 shock seems to make little difference from fully closed (slow) to fully open (fast). Not sure if it is the character of the shock or if it's broken but is there anyone who has one able to confirm that there is a marked difference between the two please?
ta.
There should be a very noticeable difference between each extremity of the adjuster. Chances are, that if you can't detect any difference then you're probably also experiencing a squelchy/hissy audible sound too?
This is commonly caused by the IFP valve core being loose and causing the IFP pressure to drop which in turn leads to very poor damping.
A service will resolve these issues
