I've got a pair of 2009 SID Team forks, and I've notice that there's some oil around the base of the damper top cap, where it screws in to the crown. I've already had the damper leak once (the normal MoCo leaking), but that time oil was pooling around the top of the blue dial/bottom of the gold floodgate adjuster. So as above, it's in a different place this time.
I'm guessing it's probably a leaking MoCo issue again? Does anyone know what seals need replacing to stop the leak?
Posted : 03/01/2012 3:17 pm
