RS Sektor Coil user...
[Closed] RS Sektor Coil users... opinions?
[#3682875]
Hi Chaps,
Does anyone use the coil version of the Sektor? How does it compare to the air version, or the air rev / Fox Float?
Any thoughts welcome 🙂
Ricks
Posted : 16/02/2012 1:32 am
I like mine. Not really ridem much else so not been able to compare them. They are better than my old 2004 fox talas's. I picked them up for £250 new so for that money they are a no brainer really. Very smooth and very serviceable.
Posted : 16/02/2012 1:42 am
Great value for money.
The damping lacks the precision adjustment of some other forks, but, they're great point and shoot forks.
I'm 14 and a bit stone with kit, the standard spring is a tad soft on my standard 150mm uturn fork.
Posted : 16/02/2012 9:53 am
Upgraded to a stiffer spring, good value fork for the money.
Posted : 16/02/2012 10:02 am
Yup, good forks, and when you get them for less than 250 new, great forks.
Absolutely brill on the front of my pitch.
Posted : 16/02/2012 10:14 am
Even better if you can find a cheap black box damper, takes the fork to a different level!
Posted : 16/02/2012 10:16 am
Mine seem to be perfectly fine in a don't notice them kinda way.
Great value.
Posted : 16/02/2012 10:25 am
Learn to do a drop down lower services on them and they will treat you well RS tend to under lube from the factory to protect leakage in packaging etc I think.. I would also agree on getting a damper upgrade in both the rebound rod and mo-co cartridge over the turnkey.
Posted : 16/02/2012 10:26 am
Spotted any deals?
Posted : 16/02/2012 10:30 am
The spring felt too soft (13 stone) in mine. Have sold them and the frame but would have tried a firmer spring if I'd kept them but then that would have put the 'bargain' price up.
Posted : 16/02/2012 10:51 am
