RS Revelations 426 ...
[Closed] RS Revelations 426 help.
[#516484]
Looking for some advice,
Just been out on my new build with Revs - 426 u-turn coil.(3rd ride)
About half way round the u-turn lost it's 'click', only 'clicking' around 110mm - 100mm.
Later on the 'click' from the u-turn dial went altogether - and the travel only seems to be 100 - 125mm ?? I don't want to force the dial so I'm not to sure what to do. Help please. Need it for the Dyfi on sunday.
Cheers.
Posted : 30/04/2009 9:43 pm
 Haze
Had something similar on mine, the adjustment became less and less - turns out the bearings under the u-turn had suffered the effects of water a little.
Unscrew the small hex bolt on the u-turn all the way out and remove the cap - there should be 3 small bearings on springs.
Apply grease and re-fit cap.
This is a bit of a shot in the dark considering yours are new, wouldn't hurt to try though.
Posted : 30/04/2009 9:50 pm
Do what Haze said. My adjuster seized solid after a couple of rides. Bit of grease sorted it out.
Posted : 30/04/2009 9:51 pm
Yup mine had bugger all grease under the U-Turn Dial from new, so I put a nice little smear in there and bobs yer auntie, smooth as you like U-Turn adjustment
Posted : 30/04/2009 9:55 pm
Thanks for your advice guys. Removed top cap (adjuster) and added grease - hey presto ! works a treat. Nice one.
Posted : 04/05/2009 7:48 pm
Posted : 04/05/2009 7:49 pm
