RS Pike U Turn - Te...
[Closed] RS Pike U Turn - Tell me More
[#1616754]
Fancy trying one instead of my Reba on my Soul.
Fancy a U turn for obvious reasons.
I weigh circa 100kg so would the stock spring be too soft?
What are peoples thoughts on the air u turn?
Posted : 17/05/2010 3:43 pm
stock spring will def. be too weak, will need an x-firm but that only covers just over 100kg.
im 98kg and had x-firm coil pikes for a while, loved them but always felt a bit soft. swapped for air u-turns which can be set up for much higher weights and love them more, would recommend.
Posted : 17/05/2010 3:49 pm
Good news Walla.
Just need to find some Air U turns in budget 😳
Posted : 17/05/2010 3:53 pm
ah you may be pleasantly surprised, ask in the classifieds?
i managed to swap my coil pikes for air u-turn that were slightly older and a bit scuffed up, serviced them at home + drop of paint sorted.
but just make sure thay have been recently serviced, too many stories of oil leakage to risk it!
Posted : 17/05/2010 3:58 pm
It won't be that bad actually. I'm about the same and I've tried it. Fine for general use. An X-firm will probably be waaaaay too heavy too, despite what RS say. Their spring weights are notoriously on the heavy side. 🙂
Posted : 17/05/2010 4:06 pm
fair play PP, as with all things i guess it depends on where the OP will be wanting to ride. heres what Tim Flookes has to say:
The standard spring fitted in these forks is a Medium, which is suitable for a rider weight of 65-75kg, all kitted up. If you’re over this, you’ll need a Firm or X-Firm spring. If you’re over 100kg, you’d be better to consider an air fork as the X-Firm won’t be suitable for extreme riding.
Posted : 17/05/2010 4:09 pm
PeterPoddy - Member
Interesting......
The coils are considerably cheaper.....hmm.
Are they much heavier than the Reba's
I'm also pretty heavy and running coil U-turn Pikes with the standard springs. Perhaps it's because I'm not that agressive a rider but I've finding the stock springs ok and haven't noticed the forks bottoming out yer although I'm getting plenty of travel.
Posted : 17/05/2010 4:12 pm
Yep, they've changed their tune from when they sold me a firm rather than an X-firm spring a few years ago, and told me exactly what I just told you, which I found to be right on the money. My Pitch came with the standard spring and I rode it round as it was and only fitted a firm when I was going to the Alps last year
Right now I've got a Lyrik on the bike, with the standard spring in it too. I've got a firm ready for the Alps again, but I'm not sure I really need it. We'll see. I have a mate who must be about 13 stone who switches between a standard and a SOFT spring on his Pikes (on a Heckler) too. Food for thought?? 🙂
Posted : 17/05/2010 4:19 pm
Hi
I am about 85kg kitted up and just run the standard spring with no problems.
I could be persuaded to sell mine if you are interested as I am looking to buy something a bit longer in travel
Email in profile if you want some more details.
Steve
Posted : 17/05/2010 4:31 pm
