RS Pike travel adju...
[Closed] RS Pike travel adjust feature
[#6120755]
So im thinking of putting some pikes on my Remedy to replace the standard fox floats. Current fork is 150mm. Wandering about getting the adjustable travel version so I can drop the front on long climbs/ more xc days.
Do they work like the talas system?
Or they worth it, or just a bit gimmicky and something else to go wrong/stop working?
Posted : 16/04/2014 4:32 pm
dont know about the air version, but my coil ones are excellent and bulletproof. the coil ones are simply a dial that lets you infinatly adjust the travel between 95mm and 140mm travel
mine are also for sale....ahem (shameless plug)
Posted : 16/04/2014 5:05 pm
New Pikes are like Talas: two set positions at the flick of a dial. I've never seen the need, but you might.
Posted : 16/04/2014 5:34 pm
Ok, does it add much weight to the fork?
Posted : 16/04/2014 6:20 pm
