RP3 Airsleeve leaka...
[Closed] RP3 Airsleeve leakage Q.
 sv
Just carried out an air sleeve seal replacement service (my first one). It still is not holding air, does the air sleeve body itself have a seal on the outside where it increases in body width?
Posted : 07/11/2009 11:35 am
Hi sv. there,s a service guide on you tube.
Hope this helps...
Posted : 07/11/2009 11:42 am
The visible seal is just a wiper seal - not air tight.
Posted : 07/11/2009 12:01 pm
 sv
Thanks guys - not entirely sure what I am looking is a seal! All the wiper seals and interior seals have been replaced successfully. The one I am concerned about is on the outer air can body, basically the black can. On the high volume version the body has a step in the middle of the can. The different sized tubes that make up the can have a seal between them, it's a hard insert. Just don't know if air can leak through this. Did use the Fox guide for instructions. Emailed Mojo to check.
Posted : 07/11/2009 12:46 pm
SV,
Pump your shock up, remove from bike and place in a tub of water. You'll soon see where the leak is comming from, it will probably be from the can seal / O ring which is inside where the can screws into the the body.
Posted : 07/11/2009 2:53 pm
Another likely culprit is a faulty/loose schraeder valve core.
Posted : 07/11/2009 6:29 pm
 sv
Did the sink full of water check the only bubbles where from this mystery 'join' there wasn't a lot. It'll maybe bed in doesn't seem to be dropping the pressure tonight.
Thanks all.
(valve core checked as well!)
Posted : 07/11/2009 7:45 pm
